pcv valve tube....where does it go???
Old Apr 13, 2008 | 12:25 PM
ultra z dot com's Avatar
Default pcv valve tube....where does it go???
i replaced my fuel rails witht he fast rails and after i got done i noticed the hose/tube that connects to the drivers side pcv valve (i believe thats what it is) was pulled tight and had ripped.
i looked at it and noticed the r-tard that put it on last just fastened the rubber hose around the pcv vavle stem, and didnt put the hard tube inside the rubber jacket on... so when i was putting the rails on it basically pull it tight to the point it tore off.
my question is, where does the hose go to? and where can i purchase a new hose for it? thanks in advance.
here are some pics to help. thanks in advance.
Attached Thumbnails pcv valve tube....where does it go???-100_1492.jpg   pcv valve tube....where does it go???-100_1493.jpg   pcv valve tube....where does it go???-100_1494.jpg
Old Apr 13, 2008 | 12:32 PM
9000th01ss's Avatar
I'd suggest a dealer or find another material. I have an '01 with 81,000 miles on it and all the rubber on the pcv system is rotted and soft.
I know at parts america and autozone they have various rubber 90's, etc in the motormite help boxes.
Old Apr 13, 2008 | 12:33 PM
sroach20's Avatar
http://www.ls1howto.com/howto/geniii...kpcvsystem.jpg
Old Apr 13, 2008 | 12:48 PM
thanks guys... this says for 99+, mines a 98... isnt it a little different?
Old Apr 13, 2008 | 12:54 PM
yay! nvm. i just noticed what i missed earlier.
i was lookin at the wrong hose on the passenger side... i didnt see the one hose going in and another going out then around the to drivers side valve cover.
THANKS!
Old Apr 13, 2008 | 08:47 PM
i decided to completely redo this system. the ppl who put it together really rigged it... ill post pics after i pull it out. insane. im talking like using spark plug boots as a 90 degree elbow.... yea. i going to autozone tomorrow and getting 3/8 lines, a t connector and some hose clamps.
and ill be calling the previous engine installers on there amazing work. kinda makes me wonder what else they rigged up...
Old Apr 13, 2008 | 08:49 PM
sroach20's Avatar
just do the ls6 pcv conversion, then you will have one short hose.
