tsp catted y ?
Old Apr 13, 2008 | 11:45 PM
SwEeTWs6's Avatar
Default tsp catted y ?
Hey guys I just installed some pacsetter LT's and the tsp catted Y.... My question is did anyone ever have any fitment issues with the Y?
Old Apr 14, 2008 | 12:24 AM
Formula_LS1's Avatar
Mine fit together fine...just took a little adjusting to get more ground clearance out of it.
Old Apr 14, 2008 | 02:23 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
OHHH....If I had a nickel....
Old Apr 14, 2008 | 03:50 PM
2KThunder's Avatar
yeah i had to cut and weld mine a good bit and im still not satisfied, its not really something that can be sold in bulk due to differences from car to car. If I had a lift and better tools Im sure I could make it perfect, but I dont, and I cant afford to have a shop do it. The passenger side is fine, the drivers side the cat was way to close to the car, I did a good bit of cutting and moving around and now it rubs the torque arm every now and then but its better than before when it would start nailing the car at certain points and sounded like a jack hammer on the drivers side floorboard.
Old Apr 14, 2008 | 04:01 PM
Delaware ss's Avatar
I installed one on my friends 02 ss and no problems with fitment. Ofcourse it hit the floorboard but most y's do.
Old Apr 14, 2008 | 04:19 PM
chieftransam's Avatar
OH man mine gives me all kinds of problems. It feels like its not stop hitting the floorboard.
Old Apr 14, 2008 | 04:26 PM
I had no problems...forgot to mention that I have a lift. It just takes lots of adjustment to get it right.
Old Apr 14, 2008 | 07:37 PM
SwEeTWs6's Avatar
Im going to have a lift on wednesday..... I got so god damn pissed at it... I had to take the bracket off that is right under the driveshaft....Also it being so close to the fuel lines is makin nervous..... I ran the o2 simms for now and already threw a CEL... Hey formula and delaware ss Would you guys happen to have a pic of it so I could get a better idea? Thanks for all the input guys
Old Apr 14, 2008 | 07:49 PM
Do you want a pic from underneath the car? I can take one right now, which will basically just show how it looks from the ground, or do you want a picture of it from underneath on the lift?
Old Apr 14, 2008 | 08:14 PM
Zitty'sZ's Avatar
I have one on my car and I don't have any fitment problems . I mocked everything up BEFORE getting underneath the car to make sure everything fit together just right . After getting it installed where everything fit good I tightened the clamps just tight enough to hold it together and I drove the car REAL easy to the local muffler shop and had all the joints welded . I can easily remove and reinstall the y-pipe by myself without any problems . Also while I had exhaust system off I installed prothane engine mounts so my exhaust does not bang the bottom of the car at all .
Old Apr 14, 2008 | 09:44 PM
SwEeTWs6's Avatar
both would be awsome if possible....
Old Apr 14, 2008 | 10:22 PM
This is the best I can do now...
I'll try to get some if I have access to the lift tomorrow.
Old Apr 14, 2008 | 10:25 PM
SwEeTWs6's Avatar
thanks bro i really appreciate it
