asp pulley problem?
Old Jul 31, 2003 | 12:03 AM
rnr27band1's Avatar
Default asp pulley problem?
Here is the problem, i am finishing up my cam install, and was installing the pulley. we got the pulley down untill it was about a quarter inch from beign seated and just couldnt get it to move any more, we were bending the breaker bar we were using the tighten up the bolt. I am wondering if this is b/c of the rollmaster double roller timing chain i installed? if so is there any sure way to tell? also what should i tell the machine shop to do? thanks alot
Old Jul 31, 2003 | 02:32 AM
Inspector12's Avatar
TT-TECH Veteran
Default Re: asp pulley problem?
Hey man I just went through this and I deleted the email some one sent me but look take your pulley to a machine shop ask them to mill off .115" or 3mm and put the 45 degree
back also and re install worked perfect for me and my friend.
That is the thickness of the oil pump spacer that you used with the timming chain. Good luck sorry you have to take it off again.
Old Jul 31, 2003 | 12:40 PM
rnr27band1's Avatar
Dose your asp pully ever fully seat up to the timing cover?
Old Jul 31, 2003 | 09:57 PM
ssdungeon's Avatar
Mine said that it would not work with the double roller... What inspector 12 said
Old Jul 31, 2003 | 10:47 PM
rnr27band1's Avatar
Well i had a few others look at mine and they said it was on all the way and i put the belts on and they all lined up and i have driven the car a little bit but havent beat on it, but so far the belts havent jumped off.
