what all for puley install???
Old Apr 14, 2008 | 12:55 PM
Midnite_LS1's Avatar
Default what all for puley install???
my buddy is about to install a powerbond pulley on his ls1...he has the crank bolt and new belts, is there anything else he needs for the install? he was told that he would also need a seal, but did not know which one...
thanks in advance for the help!
Old Apr 14, 2008 | 01:07 PM
regency's Avatar
no seal needed!!!!!!! just a piece of all-thread and thick washers to fit flat on pulley and also a small thrust bearing so its easier to turn. to start the pulley on
Old Apr 18, 2008 | 12:38 AM
any install write ups? searched with no luck...
Old Apr 18, 2008 | 09:16 AM
bigti99a's Avatar
look at the cam install on www.ls1howto.com. that should give you some info.
Old Apr 18, 2008 | 12:19 PM
99blancoSS's Avatar
I'll rent you hawk618's pulley install tool if you like, I rent out a whole cam install tool package and it is part of it.
Old Apr 18, 2008 | 07:06 PM
davered00ss's Avatar
Moderator
New crank seal if $4. I would get one. Use the pully to seat the new seal. No Oil leaks this way.
Old Apr 19, 2008 | 03:03 PM
kool...ive got a buddy who has the tools to get the pulley off and back on.
so would we be able to get this seal at vatozone? gm dealerships are already closed for the weekend...
