Got the SLP lid on... yikes
Old Apr 18, 2008 | 01:55 AM
Vega's Avatar
I had the same experience because they are moldings, they do not always have the same diameter. So some are easier to put in than others.
Old Apr 18, 2008 | 03:11 AM
DaddySS's Avatar
Originally Posted by got-a-ls1
yep just use a hair dryer to heat the plastic, the maf will almost fall out. Use it to reinstall also
Old Apr 18, 2008 | 01:46 PM
BlackNiteWS6's Avatar
Originally Posted by SLPGTP
Put an SLP airlid on the car today. It already had a K&N air filter in it which was nice and saved me $67. But holy **** it's not as easy as it appears. The MAF didn't want to come off the stock sound deadening **** and then didn't want to go into the new SLP lid. Definitely sliced my fingers open pretty deep when I was trying to get the MAF off. It still isn't on entirely but there is no way it is going to leak. And I did the free ram air mod. The throttle response is a lot better but haven't tested the power since it's raining...
I bought the SLP lid and i love it. I've had almost every lid available and
the SLP was my favorite except for the QMP lid. The SLP lid is a one piece unit instead of a lid that is rigid and glued together. Just take your time
the lid with fit perfect. BTW, trash the K&N filter they dont seal that tight.
The Holley filter has extra rubber material on it's edges that seals tighter to
all LS1 lids.
Old Apr 18, 2008 | 02:25 PM
SLPGTP's Avatar
I don't think the gym thing is the problem. lol 4 times a week should be enough! But I don't have a hair dryer... I am not a girl nor do I live with one. But that would have been nice to know. I was just immersed in it and didn't want to leave the project! Just a little frustrated at it.
Old Apr 18, 2008 | 02:52 PM
andrew69_04's Avatar
your first time it can be confusing LOL. all you need is a bigger straight blade screw driver and you can have the MAF out of the stock silencer plastic deal in 20-30seconds tops. After doing about 30+ of them you figure it out. Also, on one of my cars i got in they had just a small piece of the intake tube rubber connector deals connecting the MAF to the SLP lid. Works great, SLP should send one with there lid instead of making you jam that sensor in there
Old Apr 18, 2008 | 02:54 PM
Sommer86's Avatar
+1....easiest way to go!!
Old Apr 18, 2008 | 03:41 PM
CAMAROZ28SS's Avatar
Originally Posted by ta_06374
Good thing you were'nt putting headers on....LOL
ahahah my hands are still cut up from my install
Old Apr 18, 2008 | 04:49 PM
SLPGTP's Avatar
I did headers on my old GP and that was not fun... let alone doing it on the cramped engine bay of this thing! haha I won't even like doing plugs!
But here's the new problem. The stock bellows is pushed together so much it's pushing the lid out and unclipping the clips. Kind of retarded... Will I even be able to get a smooth bellows on there!
Old Apr 18, 2008 | 06:15 PM
primer84z's Avatar
make sure you have lid sitting on the filter box in the right place. Its possible to put it on wrong and make the clips not hold correctly.
Old Apr 18, 2008 | 07:26 PM
1Loudz28's Avatar
Originally Posted by primer84z
maybe you guys should hit the gym. I just ripped it out.
lol did you eat a can of spinach first too?
Old Apr 18, 2008 | 07:34 PM
CAMAROZ28AQUINO's Avatar
i just put mine on yesterday and i had a hard time wrestling the stock unit off and the new one on, just had to heat it up with a heatgun which helped a ton!
Old May 28, 2008 | 01:22 AM
  #32
TexasSignature2002's Avatar
Sounds like my story. The maf is a little hard to get off. But the whole experience is well worth it for the lid intake and filter!!! I found that putting it on the slp lid was hard too. so i loobed it up a little vaseline and it worked pretty easy. Couldnt get it off now for my life, but its on there!!! that's what counts, i guess!!
Old May 28, 2008 | 04:44 PM
  #33
stangkiller's Avatar
yeah that maf sensor is no joke...i broke mine in the process and had to get another one. but i would have to say the most tedious stupid hard mod i did was the tbody bypass lol.... harder than putting on the prokit and the lts's. i guess cuz you expect those stupid little things will be super easy.
Old May 28, 2008 | 05:03 PM
  #34
LS1-NAVY's Avatar
heat it up with a hair dryer
Old May 29, 2008 | 05:04 AM
  #35
SSquid's Avatar
to get the maf on your new lid... use spit....
Old May 29, 2008 | 12:14 PM
  #36
mycamaroSS's Avatar
im getting scared after reading this thread ill be putting mine on when i get home from virginia, hopefully ill be lucky
Old May 29, 2008 | 12:39 PM
  #37
hlaalu's Avatar
lol..
Old May 29, 2008 | 04:30 PM
  #38
Grimes's Avatar
haha, don't feel bad....where is the guy on here that put like 9 quarts of oil in his car once? lol
Old May 31, 2008 | 11:35 AM
  #39
CGriff04's Avatar
Did the same. Except i cracked my first lid trying to put my MAF on it. Ended sending it baack to SLP and they replaced it for free!!
Old May 31, 2008 | 11:45 AM
  #40
mycamaroSS's Avatar
**** that's tight! I guess there is some room for error
