LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   bosch corvette O2's or AC delco O2's??? (https://ls1tech.com/forums/generation-iii-external-engine/904733-bosch-corvette-o2s-ac-delco-o2s.html)
SYon22s Apr 18, 2008 03:15 AM
i need an opinion from you guys, i just got my car tuned with hp tuner, mods are in my sig...and the guy who did the tune said it would prolly be a good idea to get new O2's, was going to buy them this weekend, my car has 100,000 miles on it and the O2's have never been changed as far as i know, which ones are better? anyone have either of the two? thanks
95GreenZ28 Apr 18, 2008 07:49 AM
Well the vette O2s are better cause they last longer with the heat generated by the headers. You can get either brand but I would get the 13111s if I were you
JR HAWK 9 Apr 18, 2008 08:05 AM
I am looking for a decent pair as well. From what I have read from all the online searching I have done, I would stay away from anything made by Bosch. It seems like the majority of those that are having O2 issues soon after putting new ones in are those who installed Bosch's. I just ordered a pair of NGK/NTK rear fbody ones, FWIW.
Seems like most recommend the stock AC's, NGK/NTK or Denso. I also read that someone found out at a SEMA show that NGK makes both Denso and AC O2's.....
Here are the O2 part numbers on fbody's and C5's:
NGK/NTK:
- fbody front right: 21528
- fbody rear and front left: 21544
- C5 front: 21006
- C5 rear: 21537
Denso:
- fbody front right: 234-4087
- fbody rear and front left: 234-4025
- C5 front: 234-4012
- C5 rear: 234-4617
AC:
- fbody front right: 25312196
- fbody rear and front left: 25312197
- C5 front: 25312184
- C5 rear: 25317697
JR HAWK 9 Apr 18, 2008 08:12 AM
this is all speculation, as I have not seen any evidence that this is the truth. I have read that someone ohmed out a stock FRONT O2 and a Bosch 13111 and the stock front O2 had actually LESS resistance in the heating circuit, which means MORE power (P=Vē/R).
tylerdj Apr 18, 2008 09:10 AM
On both of my LS1's I've had longtube headers and would go through several sets of 'stock' O2's. On both cars I switched to the longer vette O2's and had no issues ever again. As far as what brand, some people don't like the bosch O2's for some reason but I've never had any issues with them. I would say you won't go wrong with either one though.
darknessxyz Nov 20, 2008 01:42 PM
NGK/NTK:
- C5 front: 21006
- C5 rear: 21537
Denso:
- C5 rear: 234-4617
AC:
- C5 rear: 25317697
I bring it back from death cuz I need new O2 for my headers. My car is a 02 Formula M6 w/104k miles and original sensor. Bought 2 Bosch 13111 and most people said they sux. Reason I bought Bosch is I don't have to extend the wire.
My question is, which sensor has the long wire so I don't have to extend? Can I still use C5 rear sensor to put in my headers as front sensor? Or F-body rear sensor as front?
Also, will they work in LT1? I've a friend has 96 SS going to install headers too so new sensor is needed.
Thanx a million.
EarlSS Nov 20, 2008 02:33 PM
NGK/NTK:
- C5 front: 21006
- C5 rear: 21537
Denso:
- C5 rear: 234-4617
AC:
- C5 rear: 25317697
Which NGK/NGT do you use with long tube headers on an f-body without having to extend them?
sroach20 Nov 20, 2008 08:49 PM
ive got the fbody ngks with longtubes and have had no problems.
davidadavila Nov 20, 2008 08:59 PM
did you stop throwing codes with them or do you still have your cats
darknessxyz Nov 20, 2008 11:53 PM
So you used an extend wire with your headers?
sroach20 Nov 21, 2008 09:12 AM
i used extensions and i have high flow cats, also no codes.
WhiskeySierra6 Nov 21, 2008 09:27 AM
I've got the 13111s on a pair of pacesetters and I've had no problems at all.
2K2B4C Nov 21, 2008 09:43 AM
Corvette rear O2's are longer wires for LT headers, so no need for header extensions. BTW I'm running NTK Corvette rear O2's.
bigcraig987 Nov 22, 2008 04:20 PM
Out of curiosity since I am at 78,XXX miles now, how often is it recommended to change out the o2 sensors
NHRAMAN Nov 22, 2008 04:26 PM
I have BOSCH 13111 Rear Vette 02's..NO Extensions needed....3 years now...
darknessxyz Nov 22, 2008 04:26 PM
Don, do you need an extension on that?
SS4Luck Nov 22, 2008 04:54 PM
i have the 13111s and have had nothing but great things with them. i had one go out at first, but it turned out i had fouled plugs, since the new plugs and new 02 its been perfect
jrob56 Nov 23, 2008 03:39 PM
i have the 13111's and the first set went bad but i got them at autozone and they come with a one year warranty so i just slapped in two more no problems since, im untuned too so that might be a possible cause to the failure?
2K2B4C Nov 23, 2008 10:10 PM
No need for extension.
Obelisk86 Nov 25, 2008 11:35 AM
a little off subject, but i'm sure you guys can help me. i have Lt headers high flowcats, but i need to plug in my 02's.. i was under the car yesterday and i know i need extensions..?? but wtf. now im confused a bit.
you only need to extend the front 02's right?
PM me please, thanks fella's
© 2026 MH Sub I, LLC dba Internet Brands
