PCV system help, routing and part numbers?
I think i found the problem. My valve cover doesn't have this vacuum line. It may be the reason it's building pressure. I basically just have the piece that goes from the drivers cover over to my catch can and then to the T/B no other lines. The front of the passenger cover gets capped as does the top line on the T/B with the catch can. i maybe will pull those caps on those vent lines to relieve the pressure that's apparently building up.
