!AIR... no engine light?
Old Apr 21, 2008 | 11:09 AM
b0pric01's Avatar
Default !AIR... no engine light?
Okay, this weekend I took out the air system and was going to live with the engine light for a few weeks until I could get it tuned out. but the light went away today?! does it store itself away that fast? Ive had an o2 heater code on for like a month before it went away, is something wrong with my computer or something?
also, the three way valve in the top of the AIR system has some little cable on the top of it, was I supposed to disconnect that from the motor, because I did. thanks
Old Apr 21, 2008 | 11:17 AM
ramairJP's Avatar
The line off the top of the 3-way "solenoid" is a vacuum line which runs to a control block just forward of that. There is another vacuum line coming from the back of the motor which also plugs into that control block. Plug that line (running to the back) with a #4-40 screw and pull off all the rest. As for the code, some guys have to drive a while before it will come on.
