how to check coil packs?
Old Apr 21, 2008 | 11:19 AM
ssduane's Avatar
Default how to check coil packs?
Anyone know how to tell if coil packs are bad or not? I had a PCM issue and think I might of damaged my coil packs. The were buzzing form the wrong PCM hooked up. I pulled two coils off and measured resistence, got nothing from all for pins to ground and only got a reading off the two center pins, which read 12.5k ohms.
Haven't found anything in the search option.
Old Apr 21, 2008 | 11:28 AM
staringback05's Avatar
you can move them around or hook up a tech 2 type deal and see which one is jacked...
Old Apr 21, 2008 | 12:44 PM
transam1998's Avatar
I had 2 go bad on mine, one of them was only bad under load, that was a pia to find. Hook up a tech 2, you have 2 options, misfire detection, which should tell you which cylinders aren't contributing. Or you can start the car and kill cylinders one at a time. When you kill a cylinder and it makes no difference in how the car runs, that is your bad cylinder. Mine has the misfire detection turned off so I had to drive down the road, put the car under a hard load, wait for the misfire, then kill cylinders until I found the one that was cutting off. PIA!
Old Apr 21, 2008 | 04:40 PM
ssduane's Avatar
The cars not running yet, still need fuel system and some other stuff. Just want to see if I can check them prior to firing it up, one less thing to do later on.
