To X or not to X
Old Apr 26, 2008 | 11:26 PM
55LS1's Avatar
Default To X or not to X
I have a heads/cam/intake LS1 with headers, dual 3" exhaust with race bullets & turn downs. It sounds pretty bad *** right now, but I'm wondering if I could pick up a few more HP with an x pipe. Is it worth the $200 I'm going to spend at the exhaust shop? Thanks for any input!
Old Apr 27, 2008 | 07:49 PM
95GreenZ28's Avatar
So you just have pipes off the headers with no H, Y, or X pipe?
Old Apr 27, 2008 | 10:23 PM
tylerdj's Avatar
If you're happy with what you have I wouldn't bother with changing it.
Old Apr 27, 2008 | 10:37 PM
proelky's Avatar
Heads up to anyone and everyone! If you plan on EVER running a safety loop, there is NO way to run a full exhaust, X, H, or Y setup.
Old Apr 28, 2008 | 05:50 AM
King Nothing's Avatar
you need some sort of crossover pipe, X will get you acouple horse and H will give you a deeper tone
Old Apr 28, 2008 | 10:11 AM
jmm98LS1's Avatar
Not true. I run the lakewood safety loop on my car......
You don't need a crossover. You'd gain some decent low-mid rpm torque with an X/H merge along with a little decibel control.....along with a couple ponies up top, but nothing you'll feel SOTP. I don't run any merge on my swb, just straight 3" duals.
Old Apr 28, 2008 | 10:21 AM
95GreenZ28's Avatar
I am going to be fabbing up a H pipe setup on mine and I have a safety loop and tunnel mount TA
Old Apr 28, 2008 | 01:03 PM
55LS1's Avatar
Yes, just 3" pipes running into bullets. The only way I would justify spending the money would be for at least 10 RWHP.
QUOTE=95GreenZ28;9248983]So you just have pipes off the headers with no H, Y, or X pipe?[/QUOTE]
Old Apr 28, 2008 | 03:37 PM
i know plenty of people who disagree with you on this
Old Apr 28, 2008 | 03:44 PM
TheSilverOne's Avatar
stop giving bad information.
Old Apr 28, 2008 | 04:11 PM
jmm98LS1's Avatar
I'm sure you know that cars in the 60's-70's with dual exhaust didn't run a merge.....and that tons of high powered track cars run either straight headers or mufflers right off the collectors right? I said you don't need one.....I didn't say you shouldn't run one. Like I said, you'll gain some decent low-midrange tq and a couple ponies up top from the improved scavenging......but running one absolutely ISN'T required.
Old Apr 29, 2008 | 12:01 AM
BayAreaSS's Avatar
This is true.
Old Apr 29, 2008 | 02:30 PM
55LS1's Avatar
So is a 10 RWHP gain realistic by adding an x?
Old Apr 29, 2008 | 02:47 PM
stevied916's Avatar
not unless you're pushing a crap load of power. I wouldnt if you are going to have to pay $200 to get it done
Old Apr 29, 2008 | 05:25 PM
but if the OP doesn't want to get pulled over or get the wrong attention a crossover pipe helps with changing the tone, straight piping is just crazy loud
Old Apr 29, 2008 | 05:55 PM
blue98Z's Avatar
Yes and no on the straight pipes. If you run some decent mufflers that will fit and there are plenty that do, you can quiet it down a good bit. I've got the magnaflow bullets on my straight pipe setup and it's pretty tame compared to the LT/ LM setup I had before. I mean really tame until you get on it. Cruising at 80mph you can't hear the exhaust, just road noise from the tires, and in town 1st-4th it could probably be loud with an auto but not to terribly loud with the manuals. I like mine and will not go back.
Old Apr 29, 2008 | 06:39 PM
98mysticZ's Avatar
i would run an x i have one on mine..... some of the cars that had duals back in "tha day" sounded like ***......
Old Apr 29, 2008 | 06:41 PM
dutinsss's Avatar
an H-pipe should be a lot cheaper to run than an x-pipe since you just have to run a pipe from one side to the other and not rerun them and bring them together for the x. i'd ask them how much an H would cost before you completely rule out the thought of running a crossover.
