Low RPM stumble
Old May 2, 2008 | 12:39 PM
blk00ss's Avatar
Default Low RPM stumble
First off, I have a 403 with a FASTintake and Fast throttle body, Patriot stage III heads, 248/252 .615/.612 cam. ever since I have had the car back together with the new set-up it has had a low RPM "stumble". Say if I'm leaving from a stop sign slowly, and the rpm's are anywhere from 1000-2000 rpm's sometimes it wont act right...kind of hard to explain but it is like a stumble. It throws a check engine light every once in a while. And its always a Throttle position code. But I have swapped out sensors and it still does it. Was just wanting to get a few ideas as what else might be causing it?
Old May 2, 2008 | 12:44 PM
SSNISTR's Avatar
Dirty MAF?
Old May 2, 2008 | 01:03 PM
blk00ss's Avatar
Havent tried that yet....
Old May 2, 2008 | 02:17 PM
thebart455's Avatar
sounds like u need to get it tuned. its more than likely in the tune of the car
Old May 2, 2008 | 02:19 PM
transam1998's Avatar
Did you get it tuned? if not, do so right away.
Old May 2, 2008 | 10:01 PM
blk00ss's Avatar
Yes. It has been tuned. On the street,and dyno'd. Maybe I can try the TPS relearn...?
