flywheel run out
Old May 6, 2008 | 02:17 PM
68protouring454's Avatar
Default flywheel run out
guys what is a normal amount of run out, on a ls6 flywheel? what is the allowable run out after machining?
also i got a ls6 used for asa late model racing and the pilot bearing will not allow my ls1 t-56 to seat against the block, however a 4 spd was used behind it for racing, which pilot bearing should i get?
jake
