Doing a catback. Should I replace the Y?
Old May 8, 2008 | 10:10 AM
scottso's Avatar
Default Doing a catback. Should I replace the Y?
I am going to be doing a Magnaflow catback, car now has an aftermarket full round tube Y pipe from the last owner - its in OK shape - but has some surface rusting. I can get a dirt cheap almost brand new stock "Y".
I read a lot that suggests there really is no flow loss on the stocker. So what do you guys think - is it worth making almost the entire exhaust new while I'm at it? (I just had one cat replaced under warranty so the only "old" part would be the PS cat).
Old May 8, 2008 | 10:28 AM
95 Z28's Avatar
If you're on stock manifolds, then a stocker will be fine.
