Header Install ????
Old Aug 6, 2003 | 11:53 AM
01Z0H6's Avatar
Default Header Install ????
Will be installing my Pacesetter Headers & ORY in the coming days & had a couple of questions.?
1) 02 sim's, are these for the front/rear 02's?
2) 02 Extensions?? Front/rear?
3)My egr/air stuff, can i use the block off plates? To include the intake?
4) Will i need to use some type of RTV on the gaskets? (I have new GM)
5) Finally, What bolts do you suggest?
Thanks in advance.... Any other tip's would be greatly appreciated!
Matt.
Old Aug 6, 2003 | 12:09 PM
RAMnGO's Avatar
Default Re: Header Install ????
1 o2 sims are for the rear..
2 o2 ext. are for front if needed i routed mine kinda weird coz i didn't want them no where near the exhaust
3 sure
4 no!!
5 i used stock bolts and they did fine
and are you using a lift or jack and jack stands to do this?
Old Aug 6, 2003 | 08:05 PM
01Z0H6's Avatar
Jack stands my friend. Thanks for the reply.
