F.A.S.T. 92/92 combo
Old May 14, 2008 | 04:11 PM
dankl's Avatar
Default F.A.S.T. 92/92 combo
OK, I think I am going to threw down some $$$ on this combo. First question is: Is there a noticeable difference between the unported intake and the ported intake? Also, should I have the TB ported also, or is this not necessary due to the larger (92mm) size? This will be going into my DD, mods in sig. Any advice/input is appreciated. Thanks.
Old May 14, 2008 | 04:35 PM
Dragkid1917's Avatar
I bought the 92 ported, its probably worth the extra money. The throttle body is matched to the intake from my understanding so i dont think you need to port anything in the throttle body, i havent heard of anyone doing that.
Old May 15, 2008 | 07:34 AM
99 Pewter TA's Avatar
GM hightech mag did a writeup on this intake this month fyi. It gained 20rwhp over the LS6.
Old May 15, 2008 | 09:05 AM
dankl's Avatar
Who does the best port jobs on these 92/92 combos? I know Tony Mamo and Vengeance Racing do porting. Is all porting pretty similar, or do some guys do better work than others?
I am looking to have my 92/92 combo ported, any sponsors out there?
Old May 15, 2008 | 10:40 AM
VRacing did mine. They ported the runners, TB opening, & some inside the intake. They did good work. You can do a search for more info.
Old May 15, 2008 | 01:24 PM
JScamaro's Avatar
Vengeance also will paint your Fast intake. Do a search on it, they look very nice.
Old May 15, 2008 | 02:09 PM
dankl's Avatar
Thanks. I knew vengeance and Tony Mamo from AFR do porting. From what I hear, Tony may do a more complete porting job, but I am not sure. Anyone?
Old May 18, 2008 | 11:33 PM
MrElectric03's Avatar
TTT, also interested if any numbers have been found between a ported and un ported version.
Old Jun 26, 2008 | 08:46 PM
cookba's Avatar
im pretty sure there are hp/tq gains to be had in porting the intakes. what i would be more interested in seeing is hp/tq differences between the sponsors who port these $1k intakes.
Old Jun 26, 2008 | 11:44 PM
Johnnystock's Avatar
humm.. the results from my numerous searches is that you gain an average of 10-15rwhp/2-10rwtq. Not too shabby for +-275$!! but a Mamo port job is pricier though.
And no need to port that 92mm TB. You should open the intake mouth(port job) to 100mm and match it with a 100mm TB from rev extreme or other brand if theres any. But thats extreme. check in the dyno section; lots of crazy results from the intake itself and for the porting too. One LS1 hit 511rwhp with that 100mm!
