What epoxy to repair ls6 intake?
Old May 15, 2008 | 01:15 PM
kistlerjm9's Avatar
Default What epoxy to repair ls6 intake?
Have an ls6 intake that had a small crack by the vacuum port. Was wondering what epoxy will stick to it as the plastic safe epoxy I have no chips off.
Old May 15, 2008 | 01:33 PM
dlove's Avatar
i sanded it down and used lots of brake clean to clean it up and then used good ol jb weld. then sanded that some and put another coat on. then did that one more time.
few thousand miles later, no problems. and mine had the complete rear center port busted out
Old May 15, 2008 | 02:53 PM
kistlerjm9's Avatar
i picked up some nylon epoxy and it seems to be pretty tough stuff will let you know how it works after it cures, if it chips off then i will use some good ole jb weld.
Old May 15, 2008 | 03:11 PM
LS184's Avatar
i would use jb weld....**** is strong as hell
