Throttle Body Bypass
Old May 15, 2008 | 08:14 PM
my bandit's Avatar
Default Throttle Body Bypass
pissed me off. i was going for the clean look with one hose like people on here said so i went and spent $8 on 5/16 coolent hose just to have it not even come close to fitting . now i am going to go with the just connecting the 2 hoses together. just though i would let off some steam.
Old May 15, 2008 | 08:16 PM
99blancoSS's Avatar
Yea its two different sizes thats why the adpater/connector is needed.
Old May 15, 2008 | 08:37 PM
my bandit's Avatar
they never said that on any of the posts but i figured that out once i started. im probably just going to connect them at a carshow when i have time
Old May 15, 2008 | 09:12 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I used one hose and put two clamps on the crossover side. Hasn't leaked yet
Old May 15, 2008 | 10:10 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Unless you are tricky and run -6AN stainless braided hose from there to the radiator for a really nice, clean look
Old May 15, 2008 | 10:13 PM
mike s.'s Avatar
Thats a bit overkill.
Old May 16, 2008 | 05:35 AM
MeentSS02's Avatar
Not if you really care about the little details...
Old May 16, 2008 | 09:15 AM
99blancoSS's Avatar
I would agree ^^^^ ITs personal taste, probably looks real nice
 Michael S. Palmer
Old May 16, 2008 | 09:48 AM
Coppertone's Avatar
I used 1 peice of 5/16th and it was a bitch to get on the radiator side, but is ended up working out fine. No leaks.
In theory it HAS to do something for power right?
Old May 16, 2008 | 09:51 AM
99blancoSS's Avatar
LMAO! no not really even in theory.. well ok yes in theory but then again not really. It would have to be glowing red hot to change the temp of the air passing through the tb for 1/10000000000th of a second
Old May 16, 2008 | 01:53 PM
my bandit's Avatar
if you can tell me how to do that i will be your best friend. i couldnt even fit it when i cut it
Old May 16, 2008 | 01:56 PM
TA-Swede's Avatar
My 5/16th fit as well, but just barely.
I stretched the radiator side of the tube by inserting a pair of needle-nosed pliers and then applied some WD40 to the fitting, and then a liberal amount of force was applied.
