TD Clearance question
Old May 16, 2008 | 01:36 AM
Pntbll309's Avatar
Default TD Clearance question
So I got my TD setup on the car and of course the clearance is garbage. But Ive noticed some people getting 3/4 of a pop cans worth of clearance. Mine has maybe 3 inches. Im using the u type clamps and know those hang low, but Im talking the actual piping. So my question, have any of you had an exhaust hanger welded on the X to hold the pipe up and not let it sag at the X? Or what can I do to fix this?
Old May 16, 2008 | 01:49 AM
Nimitz87's Avatar
the X is the lowest spot?
the lowest spot on most cars are the mufflers, or the headers, mine are the bullets but I can still squeeze a soda can under there.
pics of your setup...
Chad
Old May 16, 2008 | 02:15 AM
Pntbll309's Avatar
Chad
As soon as daylight comes Ill post pics. I decided to say screw it and go to the muffler shop as well and see what they can do for me. I scrape on EVERYTHING. I knew they were bad but damn.
Old May 16, 2008 | 02:21 AM
Nimitz87's Avatar
hopefully you can get it figured out...my duals are low, but it only scrapes on those huge speedbumps....
Chad
Old May 16, 2008 | 02:25 AM
Pntbll309's Avatar
Chad
I wish...I scraped on a dip on the highway today. I was like "I hope my heads/headers will forgive that one".
Old May 16, 2008 | 08:12 AM
tylerdj's Avatar
Is it the TSP duals? You may have the X-section upside down if so. We had it upside-down on an install before and it will make the X and the mufflers hang really low.
And did you mount the hangers that are attached to the muffler to the car? With those mounted there's no reason the X should be 'sagging'.
I've installed many of these systems and every one of them have tucked up very very well. Let us know what you find out
Old May 16, 2008 | 08:34 AM
Pntbll309's Avatar
Im about 90% sure its a TSP system, thats what I was told. I didnt even think bout the X being upside down, it didnt look like anything was angled.But the rear hangers are mounted through the rear seatbelt mount holes. I can push the system up by hand but dont want to stress the headers.
Old May 16, 2008 | 12:05 PM
Full-Force's Avatar
Make sure the x is not upside down. With the TSP system the pipes are welded to the x so you cant adjust it. If not for that you could rotate the pipes inside the x which will angle the muflers up and put them higher than the x itself.
 Michael S. Palmer
Old May 16, 2008 | 01:02 PM
tylerdj's Avatar
The way your describing it, it sounds like the x is upside down. It's hard to notice it until you have it installed but when we had it on upside down the X piece and the mufflers hung really low.
Old May 16, 2008 | 01:35 PM
Pntbll309's Avatar
Im going to flip it tonight. That would really make me LOL if thats what I did. Thanks guys, your infos helped a TON, and Ill let you know and post pics tonight.
Old May 18, 2008 | 10:19 PM
Pntbll309's Avatar
Update:
I took everything back off and tightened it all back up. I flipped the x pipe over. And made sure everything was tight and would sag. I got about 3 more inches out of it. I also hung the dumps higher. Ill get pics up soon, I also need to get it welded. Sounds like I have a miss or a leak.
