exhuast leak!!!
Old May 19, 2008 | 10:33 AM
NeedaV8foundation's Avatar
Default exhuast leak!!!
ok so i have hooker LTs and the hooker 3" ORY and the connections between the headers and the Y-pipe are leaking. i used what came with the Y-pipe which was a collar clamp which wasnt as bad but still leaked. after adjusting and messing with those forever i tried using a regular muffler clamp and that just made it worse. and yes i know its not made for using on headers but w/e. anyways anyone got any ideas?????
Old May 19, 2008 | 02:59 PM
bump? anyone?
Old May 19, 2008 | 04:23 PM
95 Z28's Avatar
I used to have leaks both with U clamps and band clamps. Now, I made a homemade tin foil gasket type thing to put under my band clamps. Not a single leak all the way back to the tailpipes. All I did was rip off a few feet of foil, folded it lengthwise, folded it again, wrapped around pipe junction, used a small piece of masking tape to keep snugly in place, clamped that band clamp down on top of it. Hope that helps.
Old May 19, 2008 | 09:58 PM
pmd ya, anyways i found some 3" band clamps on summit, will this work?
Old May 19, 2008 | 10:02 PM
95 Z28's Avatar
Yes. Get the "lap joint" ones if the pipe connections are a slip fit. Otherwise just get the flat ones. I returned your PM and I'll try to get some pics for you tomorrow that I'll post up.
Old May 19, 2008 | 10:06 PM
plaf713's Avatar
i just got my car back from the LT swap and i have band clamps and it still leaks, i am going to try and put something under the band clapm to get a perfect fitment
