LS6 Intake
Old May 22, 2008 | 09:29 AM
LS1Z28_98's Avatar
Default LS6 Intake
I've done a search on this to no avail. I have a LS6 itake on my 98. Is there any way to better the LS6? No $ for a FAST.
Is there a guide on porting my LS6 intake or better yet can it even be done?
Old May 22, 2008 | 09:44 AM
Pesticide's Avatar
I would leave the intake alone. Picking up ported throttle body will help your setup. Another addition that will help is underdrive crank pulley. A lot of people get into porting these poly intakes and do more harm then good.
Old May 22, 2008 | 11:09 AM
bigti99a's Avatar
+1 on no touch! the only reason you can port one is if it comes apart like the FAST. and even then you need to know what you are doing.
Old May 22, 2008 | 11:11 AM
twitchtwice's Avatar
you wont get much more out of the ls6 if you do that anyways. stick with what they say about hte TB and port that instead.
Old May 22, 2008 | 01:59 PM
LS1Z28_98's Avatar
Very Good dually noted!!
Thanks for the input!!
