How do I remove my A/C?
Old May 26, 2008 | 07:07 PM
Paint_It_Black's Avatar
Default How do I remove my A/C?
I just moved into a house finally, and I have this newfangled thing called a garage! I'm making it my man-space and will be getting jacks, shelves, pans, more tools, etc..
I don't want to do more than is needed, anyone have any step by steps or links to a write-up?
I took a few lines and bolts off, and it almost seemed like the water pump hoses need to come off, and I don't have pans or sawdust/cat litter yet so I put it back together for now....
all help is appreciated
Old May 26, 2008 | 07:17 PM
SStealth00's Avatar
unbolt the AC unit and follow the lines, its pretty simple. Make sure its empty first, you dont want to breathing in any of those fumes. I lost a decent amount of weight off my front end with the AC, AIR and EGR all out.
the water pump hoses dont need to come off. the whole unit is held on by 4-5 bolts i believe, it should come right down with those off
Old May 26, 2008 | 11:43 PM
ah, ok, I found the 4 bolts that go in at the top of the compressor on it's side, where's the 5th one? I'll jackit up and take a peek I suppose
Old May 27, 2008 | 01:11 AM
Empatho's Avatar
by removing the AC you save a good amount of weight and also clean up the engine compartment, and dont forget that its going to make it allot easier to change your spark plugs
