LS2 TB onto my 408, and now Codes, help
P1220-TPS Sensor circuit #2, according to HPT (GM manual does not state if it's TPS #1 or #2, but talks about both?)
P1221-fuel pump secondary circuit low, according to HPT (In my GM Z06 book it says it's the same as 1220, IE: one of the sensor circuits)
P1515-Electronic Throttle System Throttle Position, hpt and GM manual same
Trying to figure this out in diagnostics they all are related and send you back and forth in the manual? That 1221 and saying it's fuel pump seems to be a problem with HPT when scanning for DTC? Man, i don't know.
Anyway, seems I remember something similar to this being posted before and figured someone has the answer. Is the adapter cable wired correctly as this seems to have been mentioned before?
Also, I was getting a different batch of codes when the batt was a little more discharged,
p1120-TPS Sensor #1 according to HPT (no number like this in GM manual?)
P1220-TPS Sensor #2 according to HPT (GM manual does not state if it's TPS #1 or #2, but talks about both?)
P1221-Fuel Pump Secondary Circuit Low, according to HPT (GM manual has same description as code 1120 and non specific as to sensor 1 or 2?)
p1516 Throttle acuator Control and Module Throttle Acuator Position Performance, according to HPT and GM manual
I hope i didn't scare away potenial help here, lol, as it is a little confusing for sure.
Robert
If nothing else I have a spare LS2 throttle body that got a botched port job if you want to try it or use it for parts.
Knowing your ""Thrifty" aka "Cheap"
, did you get a LS2 TB harness adapter or did you make your own ?A search of LS2 Throttle Body adapter came up with a bunch for about $45-50.
Robert
