Electirc water pump
Old May 30, 2008 | 11:27 AM
Bluvette28's Avatar
Default Electirc water pump
What are the benefits is it worth getting one? Also do i need any other parts with this?
Old May 30, 2008 | 12:00 PM
teke184's Avatar
higher coolant flow for cooler running and in turn more power
reduced accessory drag on engine for more power
ability to run pump when engine is off to cool off things at the track
you'll have to wire it up, so maybe some fuses or a pre-made wireing harness. and i think the mez unit requires an old style SBC thermostat ($5).
figure 10-15hp gain depending on your application
but at almost $600....ouch
Old May 30, 2008 | 12:04 PM
firefighting1101's Avatar
not worth doing on a street car...mechanical pump is a lot safer to run, and they do have some aftermarket high flow pumps for better cooling aswell.
