HELP!! Longtubes/T'Ds running like shiz!
Old Jun 1, 2008 | 05:08 AM
First Spray777's Avatar
Default HELP!! Longtubes/T'Ds running like shiz!
Whats up? Havent posted in a while,
anyways so my set up b4 was a lid/SLP MAf/free mods and stock manifolds/cats and just an open Y(pulled off the I pipe) i dynoed 333hp 350tq.....the car ran PERFECT
so now i just installed some pacesetter long tubes with STRAIGHT pipes with some Dynomax bullets on the back, No X pipe no H just straight, my AIR tubes are just hanging there no tune nothing, im running rich as **** and the car runs like dog **** idk why!! to rich is it?? idk why the hell its running like that the car idles at around 500-800ish rpms and on start up it takes a while n is all kinds of fucked up,...also my coolant temp guage isnt working i replaced the switch but i think the wires or SOMTHING might be messed up, the fans allways stay on so idk if that has anything to do with it. The basic problem is WTH did i do wrong?? i need a tune? or what? has anyone else had this problem??
BTW ive had a long saturday night so sorry about all my typos/bla bla bla if you can understand this haha, please help me out
Old Jun 1, 2008 | 08:12 AM
95 Z28's Avatar
Could be a tune. I would check/possibly replace your plugs. A cracked plug could be contributing to the car running like ****. Just an idea.
Old Jun 1, 2008 | 11:18 AM
Brian2006's Avatar
most likely it's one of your ignition wires
Old Jun 1, 2008 | 04:45 PM
yeah i was thinking that, i checked the wires n they seem fine, idk? i was also gonna change the plugs im running TR6's because of my 125 shot but i havent sprayed it since the headers, but **** just out of no where it can dumpfuel/ect n what not? eh changin plugs 2 day.....
Old Jun 2, 2008 | 01:29 AM
Blazingz28's Avatar
I believe the coolant temp sensor is near the front bolt of the driver side header, probably unplugged.
Old Jun 2, 2008 | 01:35 AM
94'BLKBRD's Avatar
Common problems after header installs>>>>plugs/wires
Old Jun 2, 2008 | 09:11 AM
nitrouspowrdss's Avatar
How about when the coolant sensor in the head is unplugged or the harness is melted/burnt/shorted it will run like ****. PCM relies on Coolant temperature switch for switch between open loop closed loop.
Old Jun 2, 2008 | 09:26 AM
stevegrizzle's Avatar
Pull the fuse for the AIR PUMP in the passenger side box. You will get a light but at least you will know that is not contributing. Also, what did you do with the egr?
You need to get a tune and have all the things you !'ed turned off.
Old Jun 2, 2008 | 10:33 AM
dankl's Avatar
Coolant temp guage will def. screw with the way your car runs. I had the same issue after my mods. My sensor wasn't working properly, so the car never knew how much coolant to run. End result is it runs very rich, plus the headers with no tune will have you rich also, typically. Get a tune and all your sensors/plugs/wires checked while your at it. Should be fine afterwards.
Old Jun 2, 2008 | 08:08 PM
nice, idk i pulled my 2ed or 1st cyl plug n its black!!! rich? eh the SES light states "engine coolant temp guage high volts" so im guessing its the wire ijust replaced the switch, so idk what 2do butthanks for all the help!! 02's didnt have EGR, definatly dooing plugs 2marrow and finding a tuner
