Serpentine belt...
Old Jun 2, 2008 | 09:59 PM
Grewe02's Avatar
Default Serpentine belt...
Can anybody point me to a serpentine belt that will fit? I've tried about 10 different ones from the parts store.
98 motor with ASP 25% Underdrive Crank Pulley and no A/C.
Thanks.
Old Jun 3, 2008 | 08:10 AM
fatdave's Avatar
Thats the same pully I use, but Im also running the matching Alt pully as well. The number for the underdrive crank pully with the stock alt pully is 760K6
Old Jun 3, 2008 | 09:11 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
760K6
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jun 3, 2008 | 11:55 AM
Grewe02's Avatar
760K6... They'll have that part number at the parts store? Or do I need to order it from somebody?
Edit: Found it at Thunder Racing. Does anybody know if I can buy one of these over the counter? Or is this an online only type of belt?
Old Jun 3, 2008 | 01:31 PM
You can get it at oreillys or pretty much anywhere
__________________
Old Jun 3, 2008 | 07:58 PM
SweeTbone's Avatar
I used the 760 with the stock tensioner and I ended up throwing the belt. It would always try to walk off. I had to keep checking under the hood to see if it was off a rib. I went with the Gatorback 4060755 and I haven't had any problems since. It was a little tighter to get on being 1/2" shorter, but it worked. I'm still going to pick up an adjustable tensioner though.
Search both #s in this forum (External Engine), 4060760 and 4060755 and you'll come across some good threads.
