Prothane/Clamshell install help
Old Jun 6, 2008 | 10:57 PM
FadedFD's Avatar
Default Prothane/Clamshell install help
Before I tighten the bolt and screw down, I just wanted to make sure that the washer is in the correct place. I lost my instructions and just sorta figured out how the bushing goes in but am not sure about where the washer goes. Can someone confirm before I tighten and it eats into the powder coating? Thanks dudes
Old Jun 7, 2008 | 03:44 AM
35th SS's Avatar
had mine on the opposite side.looks like you got the tabs on the correct side also.good luck.
Old Jun 7, 2008 | 10:03 AM
FadedFD's Avatar
So do I need to put the washers on the back side of the clam shells? Or did you mean you had the bolts facing the other way? Thanks.
Old Jun 7, 2008 | 10:17 AM
35th SS's Avatar
your bolts are correct.I mean washers on the back side of the clamshell.pretty looking powdercoat btw.
