dipping idle after ls6 intake install
Old Jun 8, 2008 | 05:37 AM
Justin00SS's Avatar
Default dipping idle after ls6 intake install
Just finished an LS6 intake install on my buddie's 2000 camaro.
Its seems to run fine. But after he revs it the idle dips down to about 300 or so then back up to 5-600 then idles fine.
wtf mate? Did we miss something?
Old Jun 8, 2008 | 09:30 AM
Martin HD-28's Avatar
Check your vacuum hoses on the rear of the intake.
Old Jun 8, 2008 | 09:31 AM
95 Z28's Avatar
Also interested in some possible solutions for this...
Old Jun 8, 2008 | 10:05 AM
bigti99a's Avatar
yeah i would check all the vaccum lines. also make sure the TB and other sensors are plugged in. i had to slightly adjust my ported TB after my install.
Old Jun 8, 2008 | 11:44 AM
Do you hear any leakage at all? Take a garden hose or something, put one end to your ear, walk the other end around the intake and listen for a leak. Also double check your torque on the 10 intake bolts, 89 in/lbs.
Old Jun 8, 2008 | 11:55 AM
darkwolfWS6's Avatar
I have the same problem with mine once its been in storage for a while, it cranks up but wont stay running until it gets up to temp, and the idle drops all the time.
Old Jun 8, 2008 | 07:10 PM
Justin00SS's Avatar
well the idle fixed itself.
We did break the opsu though.
Old Jun 9, 2008 | 12:15 AM
alc80's Avatar
yea i think the pcm fixed itself, drove smooth to the house. oil is still pegged to 80 though
Old Jun 9, 2008 | 08:43 AM
bigti99a's Avatar
yeah have fun getting to that with the intake on there. i hope you have a super deep 27mm or 1 1/16th socket.
Old Jun 9, 2008 | 12:15 PM
98Camarod's Avatar
Your oil pressure sending unit is broken.
Old Jun 9, 2008 | 01:04 PM
Justin00SS's Avatar
way ahead of you. lol
