Making A Custom Y... Need Some Advice
Old Jun 8, 2008 | 09:41 PM
TORCHD 02 TA's Avatar
Default Making A Custom Y... Need Some Advice
I am going to be buying parts to make me a custom Y, b/c as all of you know all aftermarket Y Pipes SUCK!!!!!!!!
So i have a website that has SS mandrel bends, i have had some help and been pointed in the right direction on what to do. I have already purchased the Flowmaster 3" X 3.5" merge and will need to get the Flowmaster 3.5" X 3" reducer.
So my question is do i want the Y pipe to be made of 45* bends or 90* bends? Or do i want a combination of both? And the bends are as follows. Steel bends, no leg bends and short leg bends. SO i need help decind what angles and what bends.
And since i am doing an O/R Y should i throw in a bullet (which bullet) muffler to cut down on some rasp?
Here is what my plan is
3" custom O/R Y + GMMG C/B
Old Jun 8, 2008 | 09:59 PM
01 Red WS6's Avatar
4 90's. That's all we used to make mine.
I think the GMMG will drone so I would throw a bullet in there I can't tell you what kind to get though
Old Jun 8, 2008 | 10:24 PM
Full-Force's Avatar
You can take a U bend and cut it in half then flip it and weld it back together to make an S bend for the passenger side.
The driver side could be done with 2 90's and then a 45 at the header. You could also use all 90's but its cheaper to cut a single U bend in half and it makes like two 90's.
Old Jun 8, 2008 | 10:44 PM
01ss#5536's Avatar
I have a dynomax bullet muffler in my I pipe. I am thinking of getting another chambered muffler to replace it. It still has some rasp.
GMMG without cats is VERY Raspy.
Old Jun 9, 2008 | 05:38 AM
Thanks for the info.... that is what i needed
I should prolly put a bullet muffler either on one end of the merge and the other end of the i pipe. or maybe somewher in the i pipe? Which bullet muffler should i get though?
I hope it wount be to raspy with no cats and my cam
i was told to get
3' of straight pipes
(4) 45* bends
(1) 90* bend
Old Jun 9, 2008 | 08:36 AM
Were your pieces no leg bends, short leg bends or long leg bends?
WTF does the term "LEG" bends refer too???
Old Jun 9, 2008 | 12:09 PM
lilbuddy1587's Avatar
Why not use another chambered muffler to keep that "unqiue" sound? How about a 3", 18" long powerstick ?
Old Jun 9, 2008 | 12:31 PM
hmm never thought of that. were can you get powersticks?
Old Jun 9, 2008 | 07:07 PM
so what bullet should i run then to cut down on some rasp?
There is a summit bullet muffler for 19.95 looks like a dynomax
Old Jun 9, 2008 | 07:55 PM
lastcall190's Avatar
I would assume it means how much piping comes after the bends. Short leg is as it indicates, as is long... no leg bends? Not a clue.
-J
Old Jun 9, 2008 | 08:22 PM
Edit-
Here's the sponser that carries them:
http://www.eadperformance.com/catalo...7409729b3ace78
Old Jun 9, 2008 | 09:13 PM
CAMAROZ28AQUINO's Avatar
why you ditchen your h-pipe for Y pipe?
Old Jun 9, 2008 | 10:26 PM
change of pace i guess. I miss the sound of GMMG. i had when i was completly stock, now i want it now that i have been cammed
Old Jun 10, 2008 | 12:23 AM
01 Red WS6's Avatar
All my bends are from Magnaflow so whatever is listed on their site is what I have. I can't remember how long the legs were. Legs refers to the pipe after the bend.
Old Jun 11, 2008 | 05:54 AM
Thanls to all that cleared up the 'leg bends" i think i found the right bends for what i am going to do
Old Jun 11, 2008 | 10:55 AM
I got my Flowmaster merge today.. Wow what a nice piece, i can see why QTP usues this. This piece will out flow any other aftermarket merge out there hands down.
Old Jun 11, 2008 | 10:47 PM
01 Red WS6's Avatar
The flowmaster merg is huge. I have the 4" one on my y pipe because I was planning on building a full 4" catback but changed my mind once I started ordering the 4" bends to do it. Stainless bends were expensive
