front o2's vs. rear o2's
Old Jun 11, 2008 | 12:10 PM
KC21386's Avatar
Default front o2's vs. rear o2's
First, I have searched and there is way too many threads containing 'o2 sensor'
My question is:
Are the front and rear o2 sensors (the sensor itself) the same piece of hardware. If I broke a front o2 sensor during my header install, can I replace it with one from the rear that will no longer be used?
Old Jun 11, 2008 | 12:30 PM
LPTXZ28's Avatar
yes you can
Old Jun 11, 2008 | 01:07 PM
KC21386's Avatar
Awesome. Thanks, and lets hope thats whats wrong.
Old Jun 11, 2008 | 06:04 PM
spy2520's Avatar
how'd you manage to break a sensor?
Old Jun 12, 2008 | 12:07 AM
wtomlinson's Avatar
when i was taking mine out of the stock manifolds, i stripped one and had to use one of the rears. works perfect.
Old Jun 12, 2008 | 11:21 AM
KC21386's Avatar
I was being dumb because it was late, and I needed to finish so I could drive my car to work in the morning. I was using a pipe expander to make the collector on the driver side header round again. The shaft of the pipe expander got longer and longer and crunched the tip of the o2 sensor a little bit inside the header.
Turns out one of the spark plug wires was only on ONE click instead of TWO onto one of the coil packs. o2 sensor seems to be working, only threw codes p140 and p160 for the lack of rear o2's.
