True duel ?
Old Jun 16, 2008 | 12:31 PM
93blacktransam's Avatar
Default True duel ?
if i run 2 1/2 true duels with an x pipe dumped at the axle with no muffs or cats will it make my car run bad or loose power or anyhting ...BEcause of backpressure or the scavaging effect or will i be ok
Old Jun 16, 2008 | 12:36 PM
817Borla's Avatar
Old Jun 16, 2008 | 09:55 PM
94TRANS's Avatar
bump, curious as well, cant decide between 3" or 2.5" for clearance?
Old Jun 17, 2008 | 12:43 AM
DropTopBird's Avatar
Honestly I doubt it will make a difference unless you start getting into high horsepower levels (~500+). I am actually going down from 3" tsp duals to a custom bent 2.5" system. If you go custom, both can be tucked pretty high but the bigger the pipe the less ground clearance you will have. Good luck
Old Jun 17, 2008 | 11:16 AM
i am just woundering if you run streight pipe with an x pipe no muffs or catts .and dumped if it will make me loose power or make my car run bad.....
Old Jun 17, 2008 | 12:21 PM
Nope running them dumped shouldn't do either of those. A lot of people run dumped x's w/ no problem.
Old Jun 17, 2008 | 12:24 PM
teke184's Avatar
i ran 3" xpipe on my cammed car...for 6 months i ran straight pipes.
put on mufflers and could tell no difference.
except in my hearing quality.
they are LOUD...in a bad way...straight piped.
