Where to pressure check a FAST intake?
Old Jun 19, 2008 | 04:23 AM
00 Freak's Avatar
Default Where to pressure check a FAST intake?
A while back I did the stupid thing while installing my FAST intake. I didn't change the bolts on the valley cover and i cracked the buttom of it. I used u JB weld plastic weld and it seems fine. I installed it started it up after a H/C install. So i really dont know if it really helped because the car is not tuned. Well the intake is off now because i had a exhaust leak and would like to get it checked before i install it again. Any ideas where i can get it checked or some way to check for leaks. Maybe some soapy water and then let it dry?
Old Jun 20, 2008 | 05:30 AM
00 Freak's Avatar
Do i just have to find out the hard way? Anyone have any ideas?
Old Jun 20, 2008 | 05:36 AM
crzytown69's Avatar
maybe take some rubber or plastic and put it over the end where the TB mounts and seal it real good and then put that end down in a tank of water and blow some compressed air in where the map sensor goes in the back
