Intake Question
Old Jun 20, 2008 | 07:34 PM
SLP Camaro's Avatar
Default Intake Question
I have an LS6 Intake....Is there any need in getting the Fast Intake or can I just get a bigger TB?
Old Jun 20, 2008 | 07:43 PM
Funkster's Avatar
Get a ported TB. anything else is pointless until you can afford a 92/92. You won't NEED the Fast until you are H/C more than likely.
Old Jun 20, 2008 | 07:44 PM
DVS99TRANS's Avatar
+1 to that. The $1200 it would cost could go towards something a little more power productive.
Old Jun 20, 2008 | 08:20 PM
SLP Camaro's Avatar
I was thinking about running the 85mm BBK TB
Old Jun 20, 2008 | 11:58 PM
DVS99TRANS's Avatar
A ported TB won't be to far behind the BBK and will save you a couple bucks. Remember the LS6 can only flow so much and the stock TB ported is about good in my opinion.
Old Jun 21, 2008 | 12:39 AM
Jantzer98SS's Avatar
The 85mm BBK doesn't have a good application. On an LS6 intake you're better off with a ported stock throtte body. The 85mm intakes don't keep up with the LS6 intake. And the BBK won't physically bolt on a fast 90mm intake, so it's not a good mod.
Old Jun 21, 2008 | 10:15 AM
themack56's Avatar
the fast outflows the ls6 on any application, its like when people say the stock maf is good for 500 hp, that may be but its still a restriction, go for the fast intake, i remember i put mine on when i just had a cai and still the stock manifolds, i felt the diff, go for it and dont look back,
