tpis modded 90mm LS6
Old Jun 23, 2008 | 01:04 AM
disavowed10's Avatar
Default tpis modded 90mm LS6
http://www.lingenfelter.com/store/100-191.html
what do u guys think of this?
i just ordered it
Old Jun 23, 2008 | 01:25 AM
180ls1's Avatar
for $850?
Old Jun 23, 2008 | 07:25 AM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
it has an option to send your ls6 intake back for a 500.00 refund.
350.00 aint bad for a stealth looking intake
Old Jun 23, 2008 | 07:44 AM
fortmyerspolice's Avatar
I want to see some dyno numbers before and after.
Old Jun 23, 2008 | 07:48 AM
s346k's Avatar
please post some sort of result after switching intakes. be it track, dyno, whatever. this is an interesting intake. naturally according to lingenfelter this 90mm ls6 intake performs within 5 rwhp and rwtq to a FAST? for $350 (for those of you with ls6 intakes) not bad.
Old Jun 24, 2008 | 04:08 PM
Default Nnooooooo!!!!!!
DAMN IT!!
Not smog legal!!
Had to send it back
Too good to be true
Old Jun 24, 2008 | 04:11 PM
bigti99a's Avatar
screw smog. somebody else every buy/test this?? i am very curious as well...
Old Jun 24, 2008 | 04:48 PM
LS1-NAVY's Avatar
dood you dont need egr because 01 and 02'[s didnt
Old Jun 24, 2008 | 05:20 PM
Intercooler2's Avatar
Wonder how it gets attached? I have a friend that can machine like a champ and has plastic welding capabilities where these can be done much cheaper. Just need to figure out how they attach the new inlet.
Old Jun 24, 2008 | 05:28 PM
cablebandit's Avatar
mine is a tpis ls6 intake with a 85mm neck. I pulled the neck off once and saw that it was attached by 2 part epoxy. I put it back on with jbweld and has held up fine.
Old Jun 24, 2008 | 05:57 PM
Red99TA's Avatar
You can also get a 90 or 92 intake by selling your LS6 for $300 then paying another $450 of course then you have to buy a 90 or 92 mm TB to go with it.
Old Jun 24, 2008 | 06:01 PM
Is the FAST 90 metal or plastic?
Also would the FAST 90 be > the LS-6/90 in HP gains?
I like the plastic myself. If all that needs done is machining of a piece for the entrance and attaching with epoxy (epoxy? That's nuts!) I am sure Gene can get the right plastic rod to put a nice weld on there.
Old Jun 24, 2008 | 06:40 PM
Red99TA's Avatar
Fast 90 is a plastic. I would definitely be worried about having some jb weld holding my TB to the intake...that's nuts!
Old Jun 24, 2008 | 06:51 PM
I'm busting a gut thinking about how that would look when it comes undone
Old Jun 24, 2008 | 08:20 PM
9.81 so far in the 1/4 with 4000#.....works well. The trunk area of a vette is secured with adhesive.
Old Jun 24, 2008 | 09:22 PM
94TRANS's Avatar
thats a god idea for a new intake, but not for 850$.
Old Jun 25, 2008 | 02:09 PM
VIPERBLUELX's Avatar
Any reason you chose it over a FAST?
Old Jun 26, 2008 | 02:39 PM
NJ 2002 Z28's Avatar
I have had the TPIS Intake and t.b. on my car for a while and so does a friend of mine..
If you get it directly from TPIS then it is only $350.00 to have them modify the snout..
The other $500 is a core charge for if you do not have a LS-6 Intake..
Depending on what your set-up is and if you already have an LS-6 Intake it is worth doing..
It doesnt fall that far behind the Fast set-up
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
I have had zero problems with the intake and the way it is put together and Daily drive my car to date it has made over 420rwhp and 400ft lbs + with a small cam..
Old Jun 27, 2008 | 09:28 PM
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
Default 90 mm LS6 intake dyno results
We have dyno results of the TPIS modified LS6 intake vs the FAST intake and versus the LS2 intake on our web site:
http://www.lingenfelter.com/90mmintaketests.htm
Old Jun 27, 2008 | 11:24 PM
Johnnystock's Avatar
those results are very good!! I wasnt aware of that! Good alternative for the FAST.
