Water Pump Question inside~~~~>
Old Jun 29, 2008 | 12:00 AM
c3killer's Avatar
Default Water Pump Question inside~~~~>
Ok, the heater hose sleeves. How can I remove them from my water pump? I need to remove those sleeves and relocate them for clearance, and I have tried everything. Any ideas??
Old Jun 29, 2008 | 02:03 AM
camaroguy26's Avatar
what do you mean sleeves? you mean the hose themselves from the water pump? Pretty sure you took the clamps off. but they usually get stuck on the pipe from the water pump. Twisting it usually breaks it loose, if you can't do it by hand get a pair of pliers and grab it gently where the clamp was. If all else fails cut 'em off and get a new set.
Old Jun 29, 2008 | 05:47 AM
stevieturbo's Avatar
I imagine he means the actual steel inserts the rubber hose pushes onto.
I guess a lot of heat, and some brutality might remove them. As for putting them back in.......
