Summit Racing underdrive?
Old Jul 5, 2008 | 11:38 PM
Intercooler2's Avatar
I call that 12 lbs. What does the stocker weigh? Don't know how deep the belt sits in the groove on the SLP units but this one has a nice clear finish (clear powdercoat I believe) and pretty decent depth to hold the belt.
Old Jul 6, 2008 | 10:13 AM
01ssreda4's Avatar
i think im gonna pick one up soon....
Old Jul 6, 2008 | 11:15 AM
I looked around at how much the new and used ones were going for and it was a little nuts. This is a high quality SFI approved 25% underdrive with good instructions on install, belts and bolt to take the guess-work out of it. Don't think anyone will be disappointed!
Old Jul 6, 2008 | 02:32 PM
Black99CamaroSS's Avatar
+1 on how much the stock unit weighs
Old Jul 6, 2008 | 05:25 PM
jrcws6's Avatar
Here are some pics of the Summit pulley I installed:
Old Jul 6, 2008 | 06:14 PM
Any noticeable drop in amps, increase in temps or A/C being hotter?
Old Jul 6, 2008 | 10:07 PM
Full-Force's Avatar
I can tell the ribs are deeper on that Summit. It looks like a good buy. Like others have said, 25% underdrive is 25% underdrive so I see no need to pay more for something else.
Old Jul 6, 2008 | 10:24 PM
NemeSS's Avatar
im convinced to pick one up,
i never saw any negative changes with a previous slp 25% under drive pulley,
i doubt this will have any bad side effects either
Old Jul 6, 2008 | 11:08 PM
jrcws6's Avatar
When I tested the car for any negative changes, the only thing I noticed after driving for awhile is the volts dropped to 13.0 with everything on. Still acceptable, but I might bump the idle to 900 with the Predator to compensate. If I rev the idle to 900 with the pedal, The volt gauge moves past 13 volts. I notice no temp changes and I live in the desert. A/C and steering both seem the same as before. I won't know for sure what kind of gains it gave me until I can get to the track hopefully next weekend.
Old Jul 7, 2008 | 05:04 AM
It will be interesting to see what you run! We both have 02's and the same mods except I will be adding LT's and a custom Y.
Old Jul 13, 2008 | 12:02 PM
jrcws6's Avatar
I went to the track last night and got a few runs in to see if the UD pulley helped my times. Well, I think my expectations were a little too high because it didn't help me that much. I would say I maybe gained 3 hp. My best time was 14.149 at 7000+ DA before the pulley and my best time last night was 14.120 with similar DA and 60' but more humid. My mph was pretty much the same as well. I know this is not an accurate comparison, but I did expect better times. I guess being above 5000ft takes more hp away than I thought.
I think it's time for more major mods to make a real difference. I can say that all my small mods combined reduced my et about 4 tenths over stock.
Old Jul 21, 2008 | 11:14 AM
  #32
SMAX's Avatar
I just ordered one and they are on back order
Old Jul 21, 2008 | 11:56 AM
  #33
sidewayz28's Avatar
all i know is DONT get a march U/D pulley.. they suck to take off
Old Jul 21, 2008 | 11:57 AM
  #34
TA1364's Avatar
I would be more interested to see if it these 25% pulleys gain anything on the track. 1 tenth a 1 mph would be nice. I think the lightest pulley you can find tho would be the best bet to gain anything.
Old Jul 21, 2008 | 12:00 PM
  #35
SMAX's Avatar
I got it for the sfi cert.
Old Jul 21, 2008 | 12:39 PM
  #36
I saw a ASP and they don't have the looks of the Summit piece. The ASP also didn't have puller threaded holes like the Summit piece.
Old Jul 22, 2008 | 04:14 AM
  #37
1BadTA13's Avatar
Is it just me or should you be runnin at least half a second faster than that .....it was an automatic but in 01 my bro had a ram air and ran a 13.0 on street tires with an exhaust and tune.
Old Jul 22, 2008 | 10:17 AM
  #38
rocksws6's Avatar
So I'm considering buying one of these but it recommends 4 different belts. The last 2 appear to be the same exept for the price but the first 2 I'm guessing the ones for the A/C are different. Ones 37 and the others 40 which one do we need? And what the difference between the last 2?
Old Jul 22, 2008 | 10:29 AM
  #39
05MBMLS2's Avatar
Installation of this damper requires two new belts GTR-4060763 and GTR-4040377.
The other 2 belts that come up in the required parts are for the GTO i believe......
Old Jul 22, 2008 | 09:22 PM
  #40
jrcws6's Avatar
Those times are uncorrected at 7600 DA (density altitude). According to a sea level correction calculation, my times would be much better. See below.
Based on:
Temp: 72.7°
Humidity: 63%
Track Altitude: 5300 feet
Pressure: 29.91 in.
Density Altitude = 7634 feet ET
Uncorrected 14.12 @ 100.4 MPH
Corrected 12.55 @ 111.58 MPH
