o2 problems
Old Jul 2, 2008 | 11:20 PM
ls1ricekiller's Avatar
Angry o2 problems
I have a 2002 trans am with full bolt ons and a cam and just recently i have had the service engine light pop on and i scan it and it says o2 sensorslow response and that there is a o2 sensorheater malfunction all in bank 2 sensor1 i have replaced the o2 and it still pops up no burnt wires so what can it be?
it is starting to get frustrating
i have no cats and i had the rear o2s deleted out of the computer
Old Jul 3, 2008 | 12:36 AM
fuseone's Avatar
did you clear the code after you changed the sensor i know it sounds silly but have to ask some times?
Old Jul 3, 2008 | 04:25 AM
WS6addiction's Avatar
If you did clear code, check for corrosion inside the connector. If that's not it, look for broken wires. Sometimes a wire can get yanked hard enough to break it inside the insulation and you can't see it. The only way to find it is by checking continuity with an ohmeter. You can push sewing pins through the wire at each end to attach the leads.
Old Jul 3, 2008 | 10:56 AM
yes i cleared the codes and there is no corrosion in the connector but i will check for the broken wires thanks for the help
