LS2 intake on LS1 fitting
Old Jul 4, 2008 | 10:28 PM
5.slow99's Avatar
Default LS2 intake on LS1 fitting
im putting the Ls2 intake on a LS1 and it will not fit with the vapor vent pipe.. how do you suppose or can i toss the vapor vent pipe? ive already knocked out egr and the air pump and already have all of the adapters for the intake to fit.
thanks
Old Jul 5, 2008 | 12:27 AM
bczee's Avatar
Pick up a set of rear plugs and front vent pipe that are used for the LS2 and you should be ok. You do need the vent pipe to ensure that the air (steam) do get vented out and not cause a air pocket.
Old Jul 5, 2008 | 01:58 AM
jetlag's Avatar
What is your reason for going with the LS2 intake? Cost?
LS2 intake w/ stock 90mm TB flows less than LS6 intake with 78mm TB
Old Jul 5, 2008 | 02:06 AM
RrCoX22's Avatar
i thought the LS2's won't fit on LS1 block/heads
Old Jul 5, 2008 | 02:09 AM
5.slow99's Avatar
yea its cost, its ported and i have the 90/90 setup and im rebuilding it anyway and i had to cut some stuff short.
Old Jul 5, 2008 | 02:13 AM
jetlag's Avatar
Well, LS2s have LS6 heads..and people use those on LS1s...I think the difference are with the cam/crank/etc
Old Jul 5, 2008 | 02:16 AM
PowerTalk's Avatar
what the hell?
Old Jul 5, 2008 | 02:19 AM
sschkade's Avatar
Exclamation
Originally Posted by PowerTalk
what the hell?
It's true and it's been discussed thoroughly... try a search bud.
 Michael S. Palmer
Old Jul 5, 2008 | 02:22 AM
5.slow99's Avatar
yea it fits but like all things theres a little extra to do
Old Jul 5, 2008 | 02:33 AM
jetlag's Avatar
Probably the same problem people swapping to LS6 intakes have... flat bottom compared to the LS1s curved?
gold98Z28's Avatar
its the same as doing a ls6 conversion, get the rear plugs as said and a ls2-6 or lq4-9 front cross over tube. i know you can die grind alittle on the ls6 intake to clear the tube, i ASSume you can do the same on the ls2 intake. just search on ls6 install and you will find all the info. also the injectors are slightly differant on the ls2, so if your running ls1 injectors you will need to get the correct o-rings to make them work with that intake.
Old Jul 5, 2008 | 02:35 AM
RrCoX22's Avatar
ya really don't understand this... hasn't it been proved time after time that the LS6 intake flows if not better than the LS2???
Old Jul 5, 2008 | 02:36 AM
jetlag's Avatar
I don't think anyone here was denying that??? lol
Old Jul 5, 2008 | 02:48 AM
gold98Z28's Avatar
yeah completely off topic. yes a box stock ls6 will out flow a box stock ls2, tho a ported ls2 will do better.
Old Jul 5, 2008 | 02:50 AM
RrCoX22's Avatar
well no one ever said you can't port an LS6 intake because I have one of those
...takes some skill and knowledge
