Magic Stick 4 Cam Performance
Was hoping to get some info on the texas-speed magic stick 4 cam.
My plans are to do as follows
Magic Stick 4
Fast 92 manifold with big mouth 92mm T/B
AFR Heads
Upgraded Lifters
Upgraded Push rods
Upgraded Rockers
Re-Tune
Generaly what times are people running with this cam and what kind of power ?
My aim is to get to the low 11's. Car weighs 1750kg, 3.73 diff gears, 3k stall and built A4 auto.
Considering this info, is it possible to get the time im after ?
Cheers
Cheers
You could also look at other brands of aftermarket heads for better piston to vavle clearance due to the vavle angle of the head. Or you could look at TSP's ported 243 (LS2/LS6) casting heads (stock vavle size) if you want to stay with the MS4.
You will need higher compression with that cam for it to really shine. I would say 11-11.5:1.
Personally I would chose the MS3 over that cam but thats just me.
