Meziere EWP dyno numbers.....
Old Aug 27, 2003 | 10:57 AM
Zero2Sixty's Avatar
Default Re: Meziere EWP dyno numbers.....
Bluebyu,
Im finishing up the install of mine tonight and I have a quick question. The instructions mention the use of RTV on the O-rings, I have only 1 O-ring that Im aware of and its on the old water inlet that I moved from the stock pump to the Meziere. Also did you use anything on the connectors for the heater hoses or did you simply thread them on and tighten ?
So what exactly do I use RTV on ?
Thanks....
Old Aug 27, 2003 | 12:39 PM
BLUEBYU's Avatar
Use the sealant on the threads of the heater hose connectors...just place a small amount in front of the o-rings. Btw, are you using a relay? If so, there is a "Acc" slot in the front fuse box for easy access.
Old Aug 27, 2003 | 01:04 PM
Zero2Sixty's Avatar
Thanks for info, the instructions are pretty unclear about where to use the RTV.
I'm running an auto 30amp relay, I have all the wiring done so I basically I just need to add the RTV to the threads of the heater connectors and bolt the unit in.
Old Aug 27, 2003 | 02:04 PM
MacGyver's Avatar
I wouldn't use RTV on the threads of the heater hose connections. I uesd permatex high temp thread sealant it's specifically made to seal those. RTV isn't made to seal threads it's much thicker than the permatex stuf I used.
Will
Old Aug 27, 2003 | 02:37 PM
Zero2Sixty's Avatar
I'll probably use ARP's teflon thread sealant then.
Old Aug 27, 2003 | 02:50 PM
Jorday's Avatar
hey, what's the difference between the versions of the pump that they sell?
Jordan
Old Aug 28, 2003 | 11:33 AM
Zero2Sixty's Avatar
Got the pump and new hoses installed last night, gave the key a turn (didn't start car) and let me tell you - I was pretty suprised how quiet this unit is. Looks damn good under the hood too.
Thanks for the help on the sealant guys.
Old Aug 28, 2003 | 01:36 PM
BLUEBYU's Avatar
