running open manifolds
Old Jul 8, 2008 | 12:37 PM
brantb's Avatar
Default running open manifolds
I have searched, and people ask about open headers, which i understand is fine. I have stock manifolds, and want to make sure that it will be fine to run about 20 miles to and exhaust shop. I dont have the 02 sensors on yet, so i dont have to worry about those getting burn up, but i also dont want to warp a valve. What do you think?
Thanks
Old Jul 8, 2008 | 12:52 PM
twitchtwice's Avatar
no its not safe. you will most likely warp a valve because the mani's are really short. easy for air to get in there and cool things off. i wouldnt risk it
Old Jul 8, 2008 | 12:55 PM
Furious_George's Avatar
yeah i'm with twitch on this one. i'd probably just put the o2s back in there and leave the y-pipe on. shouldn't cost you much more at all to have them take the y-pipe back off at the exhaust shop. should keep your sensors and valves safe.
Old Jul 8, 2008 | 02:58 PM
brantb's Avatar
dont have the y pipe. I dropped the engine in a jeep, so i am getting whole new exhaust. Think if i just weld on a couple feet of straight pipe off each collector ring it would be fine? Otherwise i guess i will be trailering it there
Old Jul 8, 2008 | 03:06 PM
frankmarroquin's Avatar
Yeah better safe than sorry
Old Jul 8, 2008 | 03:43 PM
ss.slp.ls1's Avatar
I think you would be fine with some straight pipe.
Old Jul 8, 2008 | 09:32 PM
LIL SS's Avatar
Moderator
They are cast manifold.. Welding to cast with out a tig and proper heating/cooling might not hold up even to a short trip.. Better off cutting some collector flanges with a die grinder and welding your pipe to that.
