Need a few tenths
Old Jul 8, 2008 | 04:53 PM
JBourne's Avatar
Default Need a few tenths
Have a 2000 Z28 with the following mods.
Full exhaust - L/T's, ORY, and cat-back
K&N air filter
AIR delete
SFC's
3.42 gear
Yank SS4000 converter
M/T drag radials
The car as it sits will run 12.33, but I want to get to 12.0 or better to run a class.
I will have the SLP lid tomorrow, and have lca's and relocation brackets on order. Also going to get a ported stock T/B.
What else can I do (bolt-on wise) to help reach my goal?
Thanks guys.
Old Jul 8, 2008 | 05:16 PM
ModularTurbo's Avatar
what is your 60ft
Old Jul 8, 2008 | 05:26 PM
Formula_LS1's Avatar
LS6 intake would help.
Old Jul 8, 2008 | 05:39 PM
JBourne's Avatar
Sorry, I have a 2001, it already has that intake, I don't know how I typoed the year.
60ft's are at 1.62.
Old Jul 8, 2008 | 05:44 PM
remove front sway bar put on skinnys pull out pass. seat and spare tire and jack
Old Jul 8, 2008 | 06:25 PM
bad6as's Avatar
two things that you could do is a ported t/b or go to a bigger intake, and also a ud pulley
Old Jul 8, 2008 | 06:36 PM
MikeG's Avatar
skinnies
pulley
electric water pump
remove front sway bar, jack/spare, rear and passenger seats and belts.
Make up some sort of ram air setup, like a SUX2BU or something
you could ditch the cat back and just run an open ORY, or open headers even
FAST intake/tb if you like
Old Jul 8, 2008 | 06:46 PM
LS1 Freak's Avatar
I agree with MikeG! Thats what I'd do, pulley makes a good difference, just had one installed, good bang for the $ PTB and Pulley gained me 12rwhp not much rwtq only 4
 Michael S. Palmer
Old Jul 8, 2008 | 07:07 PM
Hardtop's Avatar
Originally Posted by MikeG
skinnies
pulley
electric water pump
X2. Add the short belt to this list. My old car always picked up with the short belt.
Old Jul 8, 2008 | 09:13 PM
yeah open headers with 1.5' extensions that will help a ton. and its almost free.
Old Jul 8, 2008 | 09:32 PM
DadsZ28's Avatar
Damn 1.62 sixty ft is pretty good, what mph are you trapping?
Old Jul 8, 2008 | 10:16 PM
JBourne's Avatar
108 mph
Thanks guys.
Like I said, I will be getting the ported TB this week.
Do you think the free mods would help much? I have heard mixed opinions on those.
I forgot about the sway bar. I think I will bust that off tomorrow.
Old Jul 8, 2008 | 10:19 PM
open headers with extensions can be felt by the BUTT DYNO
Old Jul 8, 2008 | 10:48 PM
DadsZ28's Avatar
108.....sounds like you should be trapping more than that with headers, do you have a good tune on it? Throttle body should help a little ,I,m trying a ported one thurs. when I go down to the track. Maybe post your 12.33 slip and ,ill look at mine to compare to see where you might be loosing some.....but its summertime and hot out,what was the DA or temp out when you ran?
Old Jul 8, 2008 | 10:49 PM
sixvi6-camaro's Avatar
I agree 108 seems low... I'd figure more like 110 or so. I ran several 12.30's in my car with a 110 trap with a crap 1.8 60'. regardless after you get the mods and pull weight get a dyno tune or better yet get a Wideband and HPT or LS1Edit and dial in your own tune.
Old Jul 8, 2008 | 11:03 PM
JBourne's Avatar
It's got a big converter, it's good down low, but suffers up top. When I didn't have the converter, it ran 13.4 at 107 mph. Go figure.
Don't know the DA, but I'm guessing it was low. It was cooler out and we're near sea level.
I also can't seem to find my time slip anywhere. I have a few, but not the 12.30's ones.
Old Jul 8, 2008 | 11:08 PM
DadsZ28's Avatar
Yea I lost a little mph too when i put my vig3200 in also, thats normal i'm told. Have your car scanned next time you run and i,m thinking that your tune is off a little somewhere.
Old Jul 9, 2008 | 02:14 AM
Can you lock and unlock your converter if so lock it after shifting to your last gear it should help the top end.
Old Jul 9, 2008 | 02:30 PM
omcar's Avatar
adjustable torque arm, HAL adjustable rear shocks, lcas, and 3.73s.
Old Jul 9, 2008 | 03:00 PM
s346k's Avatar
jbourne - i would suggest removing the front sway bar, front & rear bumper supports, backseats, spare tire & jack. that is the free stuff.
i would suggest purchasing some strong LCAs and a nice adj. torque arm, also. also might i suggest finding some weld wheels for the track. that way you can run a 15" tire out back and 3.5" or whatever up front. will knock some more weight off and also improve your ability to hook up. also, an underdrive pulley will help. remove the short belt going to the a/c compressor, as well. oh, and remove your air filter when racing haha it consistently gained 1.5-2 mph for me at the track.
i think all you need to go 11s is a hard hook and cold night as you sit. to do so on a more consistent basis will take some weight removal and susp. parts.
