McLeod Adjustable Master
Old Jul 10, 2008 | 02:53 PM
tazinhawaii's Avatar
Default McLeod Adjustable Master
So I just finished installing my new RPS Triple disc Carbon clutch in place of the McLeod twin. I also have the McLeod adjustable large piston master cylinder installed (had it with the McLeod clutch) with a stock slave cylinder. My problem is that the slave is engaging too far. I found that it's SLIGHTLY pushing the pressure plate fingers into the outer disc causing the discs to drag, making it difficult to shift. If I only push the clutch pedal half way in, it's much better. The clutch engagement/disengagement point is 1-2" from the top of the pedal travel. So, can I correct this by adjusting the rod on the master cylinder? Also, which way do you adjust the rod to make the clutch engage closer to the floor. And finally, do I just need to put the old stock master in and hope that works.
Derrick
Old Jul 10, 2008 | 04:00 PM
Viper's Avatar
Wrong forum (manual transmission is what you want) but I would adjust the McLeod counter clockwise to extend the rod towards the master thus lowering the pedal.
Old Jul 10, 2008 | 06:54 PM
Thanks. I never actually scrolled down the front page of the forum that far before to find the manual trans section. So yes, this should probably be there instead.
Derrick
