Which Maf Sensor????
Old Jul 22, 2008 | 03:58 PM
JJ93z1SC's Avatar
Default Which Maf Sensor????
I just bought a 2002 Camaro Z28, auto and i have already put hooker super comp long tubes, borla cat back and slp lid with filter..... I was wondering if its worth buying an slp maf sensor or just porting the stock one. has anyone seen any gains on it????
Old Jul 22, 2008 | 05:09 PM
blownws6_nc's Avatar
the stock 1 is good to 500 hp.
Old Jul 22, 2008 | 05:23 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Keep the stock MAF
Old Jul 22, 2008 | 06:30 PM
colews6's Avatar
what if you have a 90/90 setup or 92/92 setup?
Old Jul 22, 2008 | 06:36 PM
69LT1Bird's Avatar
Your engine can only flow so much air, most will never need the full flow of a 90mm tb and intake. Plenty of high horsepower engines use the 85mm GM MAF.
Old Jul 22, 2008 | 06:45 PM
polarischevy05's Avatar
use the stock one if any thing you can descreen it
Old Jul 22, 2008 | 06:47 PM
DaveX's Avatar
Use the stock one and leave it alone unless your modded to the point that it's a restriction.
