will 243 heads fit on a 99 ls1
Old Jul 23, 2008 | 02:35 PM
ItalianZ28Stallion's Avatar
Default will 243 heads fit on a 99 ls1
im looking into 243 heads for my ls1 and im not sure if they will fit and or what ill have to do to about the bolts?
Old Jul 23, 2008 | 02:59 PM
99NMB's Avatar
yes, yes, yes. 243's will fit on, you will have to replace the bolts with oem ls1 bolts, or arp head studs if needed.
Old Jul 23, 2008 | 03:58 PM
ae13291's Avatar
yes it is the same **** as the LS6 the 243's work but everytime heads are removed the bolts on the motor must be replaced!
Old Jul 23, 2008 | 11:24 PM
will it raise the compression ratio on the motor from stock?
Old Jul 24, 2008 | 02:43 AM
35th SS's Avatar
it will raise a bit.
