HELP! Header install!
Old Jul 26, 2008 | 04:20 PM
Spd-Kilz's Avatar
Default HELP! Header install!
A friend and I are installing SLP headers on my 98 Formula. We can't seem to get the passenger side in. The car is on the hoist right now...
We have jacked the motor up, and ground down the K-member...it still won't go.
What else can be done?
Thank you!
Old Jul 26, 2008 | 04:30 PM
subhumanzz's Avatar
when i did those headers on my car i had to lift the pass. side of the engine and unbolt a part of the k member. then pry down on the k member and pry the header in there. good luck. mine were a nightmare so i feel you.
Old Jul 26, 2008 | 04:39 PM
35th SS's Avatar
Thank you!
your headers old style or the new ones that just came out?
Old Jul 26, 2008 | 04:43 PM
Spd-Kilz's Avatar
The old ones.
Old Jul 26, 2008 | 04:49 PM
Spd-Kilz's Avatar
Did you un-do the 3 bolts? By how much.
Thanks a lot...I really appreciate all the help.
EDIT: also...where did you pry it?
Old Jul 26, 2008 | 06:09 PM
Spd-Kilz's Avatar
YES!
Passanger side is in.
Any tips for the driver side? Do you have to take the filter off / undo the steering?
Old Jul 26, 2008 | 06:32 PM
wultdta's Avatar
YES!
I took the oil filter off when I did my headers but I didn't have to mess with the steering.
Old Jul 27, 2008 | 07:18 AM
99SSragtop's Avatar
loosen the steering arm and lift it out of the way a little.
 Michael S. Palmer
Old Jul 27, 2008 | 07:26 AM
silver30th's Avatar
^what he said, that worked for me
Old Jul 27, 2008 | 08:46 AM
HMERacing's Avatar
When I did mine I took the oil filter off and unbolted the trans mount
pryed the trans over to one side and slid the header in, then did the same for the pass side. no problems at all. took about 4 hrs or so.
do you have a copy of the install papers that come with the headers?
Just make sure you route the wires on the pass side thru the motor mount so it clears the headers and heat wrap them to prevent them from melting.
http://www.popularhotrodding.com/tec...all/index.html
I have the install guide on my pc but cant post it.???
Old Jul 27, 2008 | 08:53 AM
HMERacing's Avatar
http://www.bowlingss.com/Mods/Instal...%20Install.pdf here is the guide. It will def help if you dont already have it.
Old Jul 27, 2008 | 12:45 PM
o1ls1ssmaro's Avatar
take the starter off and slide it in from underneath
Old Jul 28, 2008 | 08:44 AM
Spd-Kilz's Avatar
Thanks a lot for all the help guys.
They are finally in after using all the above techniques, AND the 'persuader'. It was a long day, but worth it in the end.
Thanks!
Old Jul 28, 2008 | 10:02 AM
HMERacing's Avatar
glad to see you got them in. although I didnt have to remove the starter or grind on the k member or the block tab. I have seen alot of people say this is nessicary but Mine slid in just fine once the trans was moved from side to side.
