Tune after Header install?
Old Jul 28, 2008 | 07:46 PM
Greekey's Avatar
Default Tune after Header install?
Does everyone need a tune after installing long tube headers and a off road y-pipe?...Do cars run bad without getting a tune after this?
Old Jul 28, 2008 | 08:42 PM
Red99TA's Avatar
It will run okay without a tune but you'll see more power if you have it tuned for the new exhaust setup. I would think it would run lean now that you improved flow through the motor but it will smell a little too without the cats.
Old Jul 29, 2008 | 12:27 PM
slow1999blackz28's Avatar
you dont need a tune really, the car will run a bit rich but it's not that big of a deal. of course if you did get a tune you would see more power. but imo save the tune for a cam there isn't a real reason to get one at this point.
Old Jul 29, 2008 | 01:09 PM
mycamaroSS's Avatar
yea that's what im doing, im going to wait for a cam than im going to do a dyno tune
Old Jul 29, 2008 | 04:34 PM
bczee's Avatar
I installed a LS6 intake, PnP Throttle Body and Headers without tuning. No problem, not much change in idle or part throttle.. most likely I am leaving some on the table to be found later.. The PCM should be making adjustments from the reading of the O2 sensor. So.. it should be too bad as far as running Rich or lean. Anymore bolt-on's and a tune will be needed. Or if you just want to spend the $300 or so and get every bit of power... then get a tune.
Old Jul 29, 2008 | 07:31 PM
Greekey's Avatar
Called for Dyno pricing today. $550.00...isnt this way to much?
Old Jul 29, 2008 | 07:36 PM
94'BLKBRD's Avatar
^^^^thats alot if it's for a exhaust tune/bolt-ons
Old Jul 29, 2008 | 07:48 PM
Greekey's Avatar
Yea I figured that looking at some of the way cheaper prices people got it done for on here.
 Michael S. Palmer
Old Jul 29, 2008 | 08:06 PM
SSmoken's Avatar
you only have to pay once for my tuner, unless you decide you want to dyno tune. But its still way less than the price posted above.
Old Jul 29, 2008 | 08:20 PM
Red99TA's Avatar
From what I've seen most dyno tunes are $500+.
Old Jul 29, 2008 | 08:32 PM
95 Z28's Avatar
Jesus Christ...500+ for a tune? Might as well just buy HP Tuners and start learning yourself. New Era, which does excellent work, does dyno tunes on cammed cars for 350. That's where I got mine done.
If you're going to be just bolt ons for a while, then I'd go get the tune. Then if you cam the car or something, you can go back and retunes are usually only like 100-150.
Old Jul 29, 2008 | 08:50 PM
motoo344's Avatar
Ya, I've been going around untuned for quite some time. No problems, I am sure more power is too be had but its pricey. I am waiting to do my cam, but I was going to buy it for my last birthday and still haven't and its almost my birthday again lol.
Old Jul 29, 2008 | 09:05 PM
cruzc5frc's Avatar
lol hate it when that happens, my bday is coming up in nov, wish me luck, maybe i'll save up enough by then
Old Jul 29, 2008 | 09:49 PM
mycamaroSS's Avatar
im going to be paying 400 at rpm, yes that is a lot unless they give A LOT more hp than the other gays..i would say turn away
Old Jul 29, 2008 | 09:53 PM
99_SS_LS1's Avatar
when i was headers only the car ran good. I did notice that at 90% throttle it would spin the tires through 1st gear, but wouldn't if it was WOT (open loop)
