Ls6 intake??
Old Jul 29, 2008 | 02:52 PM
redbadss's Avatar
Default Ls6 intake??
Im going to be getting a Ls6 intake within a couple of weeks. Is it basically a direct bolt-on. If not what all will i have to change to put it on? And a tune is not necessary correct?
Old Jul 29, 2008 | 02:57 PM
Bizzles's Avatar
What year is the car? Mods? Stock exhaust? EGR?
If you have egr and delete it you'll throw an ses light until you tune that out.
GL
Old Jul 29, 2008 | 02:58 PM
Brian2006's Avatar
You can either grind the ribs down to fit the LS1 coolant lines or you will need LS6 coolant lines and plugs
Old Jul 29, 2008 | 03:30 PM
miller456's Avatar
grind down the ribs save yourself money im not sure bout how much searching you have done but i know theres tons of info on this issue if u do search. I did mine 6 months ago and found almost every question i had in another post already.
