Underdrive and Alternator Pulleys?
Old Aug 27, 2003 | 02:20 AM
BlackCamaroSS02's Avatar
Default Underdrive and Alternator Pulleys?
what are the advantages and disadvantages of this? Is it a good idea? Who should i buy it off of? Some info would be greatly appreciated
Thanks
~Tom
Old Aug 27, 2003 | 08:54 AM
deviate42's Avatar
Default Re: Underdrive and Alternator Pulleys?
i think its worth the money IMO.
Your power level may be a little weaker after the install for electrical. If you are doing a cam install, its a great hp to bolt on. usually 5-10rwhp increase.
Old Aug 27, 2003 | 12:49 PM
2001CamaroGuy's Avatar
really good mod....
the underdrive on the crank will get you a good 5-10rwhp, quicker spin up, and slowing the power steering pump down keeps the fluid cooler and makes the pump last longer...
the overdrive on the alternator keeps it at the factory speed so you don't have any charging problems (don't loose any hp by doing this)...
most of the hp gain comes from slowing the water pump, power steering pump, and AC compressor.....the alternator is easy to spin....
