TB bypass issues
Old Aug 6, 2008 | 06:19 PM
AMitc31100's Avatar
Default TB bypass issues
so i just installed the bmr tb bypass kit but i cannot get it to clear the pulley for thelife of me. i have tried tucking it everywhere and it still rubs.the slp smooth bellows doesn't help with the issue. has anyone else had these issues?
Old Aug 6, 2008 | 06:53 PM
Blazingz28's Avatar
ziptied mine to .. radiator hose i believe? Something around there its ziptied to . Black zipties for the win
Old Aug 6, 2008 | 06:58 PM
nor-texLS1's Avatar
+1 on the zip-ties
Old Aug 6, 2008 | 07:49 PM
1badrz28's Avatar
+1 for the zip ties
Old Aug 6, 2008 | 09:10 PM
beedo's Avatar
Use good one because I have had the chepo's get brittle when hot. $.02
Old Aug 6, 2008 | 09:29 PM
nemss1's Avatar
Wink
dont even worry about buying the bmr TB bypass kit. use fuel line hose and cut it to the lenght u need. doesnt rub the waterpump pulley and looks better too!
Old Aug 6, 2008 | 09:39 PM
jeffbab's Avatar
Does anyone know what diameter of hose to use?
I just bought a kit off of ebay that I assumed would work out of the box, but of course there is no way physically possible to get it to work without rubbing the pulley below.
Why they don't just throw in a little bit of extra hose is beyond me. What a scam.
Anyway, anyone know what hose to use?
Old Aug 6, 2008 | 09:41 PM
jeffbab's Avatar
I have sae30r6 hose that came with my ws6store catchcan kit (something else I haven't installed yet)
Can I use that? It looks to be the same size, it says it is 3/8 inch?
 Michael S. Palmer
Old Aug 6, 2008 | 09:52 PM
jeffbab's Avatar
OK, looks like I need 5/16" 30R7 fuel line.
Should have just bought that in the first place instead of wasting time with this stupid coupler that doesn't work.
Old Aug 6, 2008 | 10:21 PM
bww3588's Avatar
it works, just gotta work with it, i lengthened my hose to the radiator with 3/8 fuel line i think, (left the barb fittings and **** from BMR on) and tucked it under my TB and intake and ran it that way. basically just makes a u-turn and goes back to the radiator insted of across the pulley.
Old Aug 7, 2008 | 11:09 PM
jlrz28's Avatar
10 Second Fun Car
Just buy some hard fuel line and bend it to the correct shape then use fittings on the ends. This is what I did. Use a coat hanger for a model before bending the tubing.
Old Aug 8, 2008 | 12:18 AM
nemss1's Avatar
5/16 fuel hose is what i used. i didnt buy the TB bypass kit. bought hose and cut it to fit. runs from radiator to steam tubes
Old Aug 8, 2008 | 12:22 AM
Bowtie Boy's Avatar
Dunno bout those fancy LS1s, but on my LT1 I didnt even need a kit (was a noob). The hose coming off the throttle body back to the rad was long enough to connect back to the original line that fed into the throttle body.
Old Aug 8, 2008 | 08:07 AM
Blazingz28's Avatar
I foudn a small metal tube around the garage and cut it about 2 inches long, put it into each end of hose and a year later its still good. $free.99
Old Aug 8, 2008 | 10:56 AM
omcar's Avatar
I know a photo of this was posted some time ago..can anyone post one again?
