Victor jr. info
Old Aug 7, 2008 | 02:48 PM
1fast bird's Avatar
Default Victor jr. info
Anybody use the victor jr. intake and elbow combo?I'm thinking of using this for my 370 f/i build.My question is, can I run a 78mm t.b. on the 90mm elbow?I've seen a couple write ups on this intake but no answers to this question.I just don't see the point in running anything bigger than 78mm if the charge pipe is only 3 inches.Plus a good 90mm t.b. is a lot of $$$$$.Or should I just save the money and buy an ls6 intake?
Old Aug 9, 2008 | 10:20 AM
mrr23's Avatar
i am. the whole setup cost me just under $1000.00 to answer your question, you can run a stock TB if you choose. it has a thin adapter to make the neck opening a 78mm diameter.
http://www.ls1.com/forums/showthread...57#post1591957
